MAP sensor predicament
Hey guys, I have a 2000 LQ4 with a Holley Hi Ram 102mm and they suggest using the ls3 style MAP sensor. When I get a tune is it possible for them to tune the PCM to read the 2 bar map? Or what would the best option be since I will be running speed density? Thanks in advance, Jeremy
If you are not boosted, then there is no need to use a different MAP sensor.
If you are then yes you will. With HPT or EFILive and a re-tune you should be able to use pretty much any MAP sensor.
