ls2 to ls7 maf conversion
Old Jun 18, 2017 | 09:14 AM
taz68camaro's Avatar
Default ls2 to ls7 maf conversion
how do you remove the pins on a ls7 maf connector in order to do a conversion from ls2? can't find it on youtube.
Old Jun 18, 2017 | 10:51 AM
homemade87's Avatar
TAZ , Maybe this will help you . When I remove the pins I remove the purple part inside the connector . It does pop out . Then push the tab and remove the pin .
Old Jun 18, 2017 | 12:53 PM
I did that but I can't seem to release the pins. Which slot has the release tab? from the front side or back side?
Old Jun 18, 2017 | 01:02 PM
got it...thanks homemade87. I thought the purple part you were talking about was the wire separator in the back. thanks again
Old Jun 20, 2017 | 05:37 AM
homemade87's Avatar
Glad I could help . Those connectors can be a pain . Now get that thing plugged in and go leave some marks on the road .
