Bad throttle body?
Old Jul 3, 2017 | 08:06 AM
AJ1990's Avatar
Default Bad throttle body?
I have a 06 reg cab colorado with a ls2/4l65e out of an 06 gto. I'm having an issue when I plug in the A/C pressure switch it goes into "reduced power mode" and gives me a P2138 code. I do have have a high idle around 1100-1200 when hot and there is a slight high pitched noice coming from the throttle body when the truck is turned off. Could it be a bad throttle body? I've checked for vacuum leaks and everything is good. Any help would be greatly appreciated
Old Jul 7, 2017 | 12:22 AM
eb110americana's Avatar
Your trouble code is for the TPS. The high pitched noise may be the IAC.
Old Jul 8, 2017 | 06:40 PM
TipsyMcStagger's Avatar
An '06 LS2 is DBW, so I'm guessing no on the IAC.
Tipsy
