Will using header wrap help with noise?
It supposedly helps with scavenging by keeping the heat inside the headers and raising EGTs. I read that somewhere, dont know the truth behind that tho.
Enter the big question. Can you melt the exhaust with what you have? Of course you can. Any V8 or even 4 cylinder engine could probably run long enough, lean enough, to melt a typical exhaust component or even the warp the head or valve. So its our job to kind of know what the temp is, how to keep it cool, how to use these toys like exhaust wrap properly.
Short version is, if you have cheap headers, very thin, barely stainless, the wrap may accelerate the deterioration of the metal beneath. Wrap is often not recommended for those cheap, easy to ruin metal parts. On the other hand, a beefy OEM manifold is pretty tolerant of additional surface oxidation (its already pretty rusty probably). So wrap is more well tolerated there. Any other pipes? Use your judgement. If it looks sturdy, thick, stainless, I would wrap it. If you can stand to replace it? I would wrap it. If you only need it to last a year or two anyways? I would wrap it.
One word of caution, maybe just because it happened yesterday. Wear a mask when you work around exhaust wrap, and gloves. I was under the car the other day putting on a PS line and when I finished I felt some of that wrap in my mouth. Not a pleasant feeling.
I used DEI titanium wrap. IT was my first time wrapping exhaust parts, so the itchy fiber glass feeling was new to me. I also did a terrible job, kind of. It was so bad the guys at DEI face palmed... and sent me a new role free of charge to do it over. It works, even poor looking installation is very cool compared to surrounding components.
Underneath due to trapping condensation between wrap and the
Part wrapped. So cheap steal/non coated headers will not last
Very long.
And so forth, some are better than others at handling the wrap, the wet, the oil, etc... have to use your imagination sometimes. I agree that all high quality exhaust systems should be coated and wrapped if possible. Temp control is done from the cockpit.
I went over to a buddies house to look at his LS car with wrapped headers. It does "Help" with the sound in a sense. It kinda changes the sound a bit and is not as noticeable.
I will probably just end up leaving them as is. The noise is really not that noticeable unless the hood is open.
