Anyone know what these connect to?
Old Jul 22, 2017 | 11:56 PM
walterR32's Avatar
Default Anyone know what these connect to?
Anyone know what I've circled in red connects to? I've installed a ls3 into a 240sx. Only things stopping me from starting the car besides fluids and one final look over.
Old Jul 23, 2017 | 12:18 AM
timopajala's Avatar
the one in the left i hooked directly to my intake between maf and throttle body and i plugged the right one
Old Jul 27, 2017 | 11:34 PM
eb110americana's Avatar
The one on the left is the breather. When I swapped to a mechanical cable throttle body, I connected it to the tube on top of the TB. The plastic one on the right would connect to the charcoal canister purge valve. If your car has a charcoal canister by the gas tank and two gas lines going to the engine, the one from the charcoal canister gets a black plastic purge valve on it very near this connector (it's computer controlled, so there should be a harness). When that valve is open, it dumps into here to vent the fumes from the tank/canister.
Old Jul 27, 2017 | 11:49 PM
walterR32's Avatar
Y'all think I could just connect the nipple on the valve cover to the one of the intake or would that be bad? I don't have any where I can connect the hose to my intake. Unless I tap and weld a little bung onto it.
Old Jul 28, 2017 | 03:14 PM
The only problem is that the plastic one is after the throttle plate, so it won't get fresh air to it if the throttle is closed. You could put one of those small breather filters on the metal one and just cap the plastic one if you don't need it.
Old Aug 2, 2017 | 08:51 AM
01ssreda4's Avatar
Cap off the one on the drivers side, its for emissions.
