Headers 1 3/4 or 1 7/8?
Old Aug 22, 2017 | 06:42 AM
bortous's Avatar
Default Headers 1 3/4 or 1 7/8?
Hi everyone,
Hope you are all doing good and flying down the 1/4 mile listening to that sweet symphony of good old american muscle.
Anyway, I am after people's opinions on my setup and if you think it is worth upgrading the headers to the larger primary 1 7/8 size.
Here are my engine specifications:
LS2 408 short block fully built with forged internals and high end gear
CNC LS3 heads 60cc chambers 12:8.1 static compression ratio
236/244 .626 .626 114LSA camshaft from Patrick Guerra
Fast 102mm intake manifold
! 3/4 4into1 long tube headers with 3 inch merge collectors
Dual 3 inch cat back exhauust (full stainless)
4.5 inch body heavy duty ballistic cats with 100CPSI
3200rpm high stall converter
3:91 rear gear
This engine runs on pump e85
The engine is making 510rwhp which is very healthy for an automatic.
I feel though, that my power may be hindered by the smaller primaries though.
The engine is crazy fast, but I feel when foot is planted, it feels like the engine is being choked as the torque curve is there but its not intense. I can't properly describe it.
Its just the sensation I get.
Another reason I think it may be the primaries, is because, you have got all that compression, the extra rich fuel mixture running e85, plus all the flow of the heads etc, the 1 3/4 may not be enough header to deal with all this. Plus the 12 degrees of postive overlap from the camshaft.
I have seen numerous posts where even on stock LS3 engines the 1 7/8 headers have gains with zero losses down low.
I contacted Patrick Guerra and he said to me in all his testing on LS3 engines, the 1 7/8 has always made more power everywhere and these heads seem to prefer the bigger primaries.
I have noticed there are also many others who have claimed to have lost power and torque going to these but they seem a little suspicious.
Would appreciate anyone's input and advice. I can also be contacted at bortous85@gmail.com
Cheers
Old Aug 22, 2017 | 07:06 AM
Rise of the Phoenix's Avatar
Absolutely upgrade. You'll be surprised how much power the bigger headers are going to be worth.
Old Aug 22, 2017 | 07:23 AM
HCI2000SS's Avatar
Sure if you have that kind of time and money even though you have a good set of headers then yes by all means. If I was starting from scratch or my old set was rusting out then it would be a no brainer, otherwise it's not worth it IMHO
Old Aug 22, 2017 | 11:22 AM
pantera_efi's Avatar
Default Primary Pipe Legnth ?
Hi, so how long is the primary pipe ?
Lance
Old Aug 22, 2017 | 02:17 PM
01ssreda4's Avatar
Go straight to 2 inch if available.
Old Aug 22, 2017 | 08:05 PM
99 Black Bird T/A's Avatar
BortIve there have been at least one test showing 1 7/8 headers gain ~ 5 hp over 1 3/4 headers on a stock LS1. I think your set up would gain a whole lot more.
Often 2 inch headers do not fit as well as 1 7/8 if the car is a 4th gen fbody with a stock k-member. If you have an aftermarket k-member then 2 inch would likely make more peak power.
