LH6 Intermittent Noise When Cranking
Old Sep 11, 2017 | 06:51 AM
drdave88's Avatar
Default LH6 Intermittent Noise When Cranking
I have a friend with an 07 Envoy Denali. When cranking, it will intermittently have a metallic pinging sound, that sounds like something against the flexplate. It only seems to do it when it starts getting colder out. When I did hear the pinging sound, it also sounded like I could hear an electrical "snap" like something is arcing almost. The vehicle cranks and starts fine, but this issue occurred most of the time last winter and has started again in the colder mornings here in Michigan. Has anyone ever heard of anything like this before?
Old Sep 11, 2017 | 10:14 AM
You might want to check ALL connections AND grounds. Also check flexplate to converter bolts while you're at it.
