MAP sensor LS7/MSD intake?
Old Oct 12, 2017 | 07:03 AM
lowcountry's Avatar
From: Grew up in Charleston, SC live in Moncure, NC
Default MAP sensor LS7/MSD intake?
Using the GM LS7 harness/ecm designed for LS7 crate engines with an MSD intake. The recommended sensor is #12615801. I believe that is for the stock intake which uses a different mounting scheme. The MSD uses a SCHS to secure the sensor.
I see several sensors that mount like that, but not sure what is the right choice.
Anyone have a recommendation?
thanks.
Old Oct 18, 2017 | 09:32 PM
JimsNovaLS's Avatar
I went through the same problem looking for a bolt on sensor that would fit. Got the ls3 sensor which has a bolt hole in it but its in the wrong place and a bigger vacuum stem that wouldn't fit into the MSD as delivered. Wound up using an LS1 sensor that normally snaps into place and used a locktited bolt and washer to hold it in place, no problems. You'll just need to make sure your harness plugs into the LS1 sensor okay. I had a truck harness and it plugged in fine. You might look at an LS7 sensor, I didn't, if it fits the MSD and the harness use a bolt and washer th hold it in place.
Old Oct 19, 2017 | 06:49 AM
lowcountry's Avatar
""You might look at an LS7 sensor, I didn't, if it fits the MSD and the harness use a bolt and washer th hold it in place. "
Thanks. That is what I ended up doing per suggestion of another member.
Old Dec 10, 2017 | 02:51 PM
Can you post up the part number for the map sensor you used on your MSD Atomic?
Old Dec 11, 2017 | 03:57 PM
lowcountry's Avatar
I'll go take a look in the shop first thing in the morning. I thought I had the receipt here in the house, but apparently not. I'll get back to you shortly...
Old Dec 12, 2017 | 12:27 PM
lowcountry's Avatar
Part # 12644569
63011
This one does not have the molded round feature for mounting with the small screw, but works just fine with the screw if you use a washer.
There is a part # with the round feature, but I think it has been replaced with this one.
Attached Thumbnails MAP sensor LS7/MSD intake?-map1.jpg   MAP sensor LS7/MSD intake?-map2.jpg
Old Dec 12, 2017 | 05:22 PM
Awesome thanks!
