throttle cable
Old Nov 9, 2017 | 03:37 PM
ncnspcqs's Avatar
Default throttle cable
which year throttle cable do i need for a 2005 5.3 gen4 going in a 66 malibu
also i ordered this z-270 flex plate which was great for spacer on it to make up difference to TH350 trans, however it doesnt look like bolt holes are going to line up for torq converter, then my last thing i got a 145 amp alternator coming for this, but on the harness i am using it is the red/blue ecu and will work but seem to only have 1 wire setup for flat four alt any ideas on making sure this will work for sure, there wasnt any other pinouts but on the alt side there is 4 pin outs
Old Nov 10, 2017 | 01:16 PM
KW Baraka's Avatar
Originally Posted by ncnspcqs
which year throttle cable do i need for a 2005 5.3 gen4 going in a 66 malibu......
.....................I dunno.
Have you considered using a 2005 cable?
KW
Old Nov 10, 2017 | 03:56 PM
Originally Posted by kw baraka
have you considered using a 2005 cable?
Kw
genius!!
