Scraping headers fix?
Old Dec 20, 2017 | 03:36 PM
01bird58's Avatar
Default Scraping headers fix?
The kooks headers on my 02 Camaro have been scraping. It looks like a hole may finally punch through. Could a patch be welded on or would they need to be scrapped? Any others with experience on a fix? (Other than raising the car up)
Old Dec 20, 2017 | 06:06 PM
Scraping on a primary tube or collector? If tube, it would be tricky. Easier with a collector.
Old Dec 20, 2017 | 06:24 PM
qweedqwag's Avatar
No put a new set on and scrape the **** outta them too.......ID10T
Old Dec 20, 2017 | 08:58 PM
01bird58's Avatar
Its a primary tube, just before it leads into collector. Thx.
Old Dec 20, 2017 | 09:10 PM
01bird58's Avatar
Right, like I wouldn’t try buying new shorter ones. Thanks for the help.
Old Dec 20, 2017 | 10:15 PM
NEstyle's Avatar
Of course a patch could be welded on. Is this a trick question?
Old Dec 20, 2017 | 10:30 PM
Yeah, as long as the tubing isn't too thin, which just makes it a little tougher to weld.
Old Dec 21, 2017 | 09:05 AM
01bird58's Avatar
Exactly my concern.
Old Dec 21, 2017 | 09:31 AM
NEstyle's Avatar
My point is that anything can be be welded unless the headers are almost completely rotted through. In that case they are not worth fixing and and you should replace them anyway. If they are not rotted through and someone tells you they can't be welded, you need to find a better welder!
Old Dec 21, 2017 | 03:46 PM
01bird58's Avatar
Got it. No rotting, other than the scraping they are in great condition.
