Ground issue?
Old Dec 28, 2017 | 11:35 PM
se7en82's Avatar
Default Ground issue?
I am chasing a ground/electrical issue on my 2010 Camaro and came across these two ground bolts. 1 Went to the passenger side head in the front and the other went to block on the drivers side behind the alternator. Does the way it look indicate any issue or is this normal?
Old Dec 29, 2017 | 12:12 AM
I would be more worried about what the underside of the bolt heads look like. Just make sure they are clean of anything like rust, crud, oil, etc. Then look at the connectors that the bolts held down, and make sure they are very clean. You might want to check ALL grounds, as they are all vital in keeping things running right.
Old Dec 29, 2017 | 12:19 AM
se7en82's Avatar
Thanks. Any idea on where to find a diagram of where the stock ground points are located?
Old Dec 29, 2017 | 12:29 AM
A shop manual for that car should have it. You might even Google it. Stranger things have come up on it.
Old Dec 29, 2017 | 12:39 AM
se7en82's Avatar
Appreciate itI can engine grounds via google easily but looking for vehicle ground points.
Old Dec 29, 2017 | 03:10 PM
Uhh.. Look up "vehicle ground points" on Google and see what happens...
