LS2 58x or 24x? Having trouble figuring it out
If it is a 24x it will have a black crank sensor.
58x will be a grey crank sensor.
24x reluctor wheel will look like a gear with missing notches in it.
58x wheel will look like a complete rear bicycle gear. perfect gear without notches.
pull sensor look in hole.
The "high" signal must go low before TDC, NOT AFTER TDC.
This effect "calls" the #1 cylinder Intake Ready.
You are not sure which PCM is fitted, your ECU could have the same object in calibration ?
The Cam Target 4X can operate the engine with NO CS output. (limp mode)
Lance
