LS3 PCV routing without valley pan nipple
I thought I had it figured out until it started smoking like a freight train out the tail pipe and then found I had oil all inside the intake.
Currently, I have vacuum plumbed to driver side valve cover with a Beck Arney PCV valve and a sealed oil air separator. Fresh air is plumbed to the passenger side valve cover directly.
A buddy said I need something similar to the attached picture. He said the key was a catch can that can breathe so it doesn't force oil backwards through fresh air line.
Does anyone here know how it should be plumbed?
I too was having oiling problems at one time on my build. It kept pooling up oil in the back of my intake and fouling the back cylinders and burning oil. I was told to put thread sealant on the rocker bolts but that wasn't it. I thought my initial sealed catch can setup was incorrect so I went with a breather can with 10AN lines off each valve cover thinking that was the problem but that wasn't it either. In the end I had pull my engine back apart and hone and ring all the cylinders again.
OP, basically you want the fresh air (low vacuum side) going into the port on the passenger valve cover and coming from a source BEFORE the throttle blade. You can choose to put a catch can here too as at long WOT runs it can pull oil back to the TB.
You want the dirty side (high vacuum) to go to the port on the driver's side valve cover (or would be the valley cover port if it was equipped) and connect to the intake manifold after the throttle body. This is where you want a catch can plumbed.
Now, the only thing I am unsure of, is on Gen IV valve covers there is a restrictor in that driver's side port that GM uses to function as a PCV valve. So adding another PCV in line would probably be redundant, but I don't think it would hurt anything.
BTW, search the forum for the "Is my catch can routing ok" thread, sift through 35 pages and you'll become a near expert on anything pcv related, lol.
mightymousesolutions@gmail.com
even the elite catch can guys can/will help you out without needing to sell you anything
The oil is getting in and there's only so many ways it gets in. Past the valve guides on the heads, around the rocker arm bolts if the porting made it to the rocker arm bolt holes, the oil being sucked in via pcv system and last but not least the dreaded one of all past the rings! Good luck and keep us posted!
forget any above drawings and just focus on this
https://docs.google.com/document/d/1...XRmcvqNUJxjZDc
these are the instructions for what you ordered. they come with the kit and are also hot-linked on the product page of the website. please read them and then let me know any questions regarding it you may have.
provided they are followed you will have a correctly functioning catch can system with integrated pcv control
I'll keep y'all posted.
I did get video showing some blowby. I capped off the vacuum and ran the PCV lines into a water bottle to see if I could collect anything. How does this amount of blowby make you feel? See video:
https://www.youtube.com/watch?v=itneXB4lEOA
I'm by no means suggesting you not run a pcv system. To be emissions legal it's required but venting to atmosphere as a test to see if that's the issue I see no wrong doing. Another thing I noticed with my car was it wouldn't start smoking right away after start up but once the engine reached operating temp you would see some blue smoke. It seemed to be even more noticeable under deceleration then acceleration and like I said my rings on the back cylinders failed to seat.
I have manual tranny and when I got the car back together I went out on the road got it into 3rd gear and took it up to about 4g and took my foot out of it. I did this repeatedly and my car looked like a mosquito truck cruising down the road it was embarrassing but after about 10-15 times of doing that the smoking went away. Checked my plugs and I'm happy to report all my cylinders are seated.
Looking at the catch can, it appears to have a rubber flap on the breather acting like a check valve for vacuum. Looks like at idle I have more blow by than I do vacuum. (See video) When I rev and hold at 2000-3000, blow by goes away. I put a sealed oil air separator to help block any oil that might try to backfeed in the fresh air line. I can tell you the mist coming from the catch can breather smells like pure gas.
