LS3 PCV Delete?
Old Mar 26, 2018 | 02:52 PM
my bandit's Avatar
Default LS3 PCV Delete?
This idea will only be a temporary one but I'm wondering if its an option. I am thinking about running a line from the rear drivers valve cover nipple to the front passenger line to connect both valve covers. Then from that, I would just run a breather oil fill cap. I know this could cause oil mist but it would be a remote breather. This is more of a racecar than a street car. I know a catch can would be what I need, I just haven't gotten around to getting one yet and need the car up and running soon.
Old Mar 26, 2018 | 08:01 PM
01CamaroSSTx's Avatar
You could do something like this but just run 3/8 hose instead of the 10AN set up and still add a breather to the valve cover. I chose to go 10AN to make sure my system was large enough to relieve the crankcase pressure.
Attached Thumbnails LS3 PCV Delete?-20180128_110534.jpg   LS3 PCV Delete?-20180325_135716.jpg   LS3 PCV Delete?-20180325_140535.jpg
Old Mar 27, 2018 | 07:35 AM
my bandit's Avatar
So all you did was add a breather tank between your valve covers and capped everything off on your intake?
Old Mar 27, 2018 | 08:12 AM
That's all I'm running.
