LS3 double roller timing chain problem
Old Nov 16, 2018 | 06:20 AM
Nigor's Avatar
Default LS3 double roller timing chain problem
Hello, I have changed 3-bolt double roller timing chain to my ls3. Oil pump is original and timing chain set is COMP Cams 7106. Timing chain and oilpump clearance is ok, it doesnt rub. But Camshaft position sensor hits camshaft gear. What do I need?
And I guess ls2 damper fits with double roller and ls3 block?
And is it normal that camshaft moves forward and backward when it is without chain?
Also I have one very stupid queston which valley cover i should use. I have both ones, 12598832 or 12599296?
