Warm engine issue. Help !!!
Old Nov 18, 2018 | 06:27 PM
Jaredjmoore89's Avatar
Default Warm engine issue. Help !!!
I have a basically stock c6 ls2. I’ve got an issue after when the car warms up it will rev freely to redline, but if it’s wot it will stop at 3k rpms and sit there. If I let it sit still and idle long enough I can go wot and it will literally just idle with the pedal to the floor. Car runs fine other than that. No cels and fuel pressure is a steady 60 psi. What do you guys think it might be ? Car drives perfectly fine other than that. Only a wot issue. The warmer the engine the worse it gets.
Old Nov 18, 2018 | 08:08 PM
The computer does not like the engine revved to redline in neutral.
Old Nov 18, 2018 | 08:21 PM
Does the same driving
