Black friday steals!
Old Nov 21, 2018 | 04:42 PM
LivernoisMotorsports's Avatar
Default Black friday steals!
ATTENTION
*BLACK FRIDAY SALE*
GIANT BLOWOUT SALE!!!!
CYLINDER HEADS $200 OFF USING PROMO CODE *LIVERNOISCH*
ENGINES & SHORT BLOCKS $1,000 OFF USING PROMO CODE *LIVERNOISSB*
*GM/Chevrolet LS-LT4 Cylinder Heads*
w/Livernois Spring Kit is $999.99
Customer Supplied Cores, our 5-axis CNC (intake and exhaust), CNC Valve job, Install New Livernois Springs and Valve seals. All other additional parts will be a separate charge.
*Ford Modular/Coyote 32 Valve Cylinder Heads*
Customer Supplied Cores, our 5-axis CNC (intake and exhaust), CNC Valve job, Install New Livernois Springs and Valve seals. $1,299.99 All other additional parts will be a separate charge.
Don't wait on these incredible deals, before they are gone!
ENGINES:
2015 5.0 10.6.1 Pro Series
2011-14 5.0 11.5.1 Street series - LPP750104
2011-14 5.0 10.6.1 Pro series (qty 2) - LPP750103
LS2 9.7.1 Pro series 404 58T - LPP751102
LS2 11.1 Street series 404 (qty 2) 58T - LPP751103
2005-10 3V 10.1 Race Series
SBL1 2 Valve TEKSIDE Aluminum block trick flow head, boost application - LPP750111
LSA 9.7.1 Race series 429 58T, Sleeved LSA block, Dragon slayer crank 4.000" stroke, Ultra I-beam rod, coated bearing - LPP751114
LSA/LS3 419 9.7.1 Race Series, 58T
LS3 419 11.1 Pro Series, 58T
CYLINDER HEADS:
LPP761100 - LS2/6 STAGE 1 (STREET SERIES) - 1 SET
LPP761101 - LS2/6 STAGE 2 (PRO SERIES) 243/799 CASTING - 2 SETS
LPP761102 - LS2/6 STAGE 3 (RACE SERIES) 243/799 CASTING - 2 SETS
LPP761102 - LS2/6 STAGE 3 (RACE SERIES) 317 CASTING - 1 SET
LPP761104 - L92/LS3 STAGE 2 (PRO SERIES) - 4 SET
LPP761105 - L92/LS3 STAGE 3 (RACE SERIES) - 4 SET
LPP760105 - 4V Cobra Race Series - 1 SET
Old Dec 1, 2018 | 10:14 AM
99 Black Bird T/A's Avatar
Two general questions. I've checked the Livernois website and didn't see the specific details.
What CC are the chambers on the various LS heads? A lot of us like to calculate compression ration based on using our own short blocks and various piston sets etc.
With the LS short blocks what is the piston dome or dish CC? Because again a lot of us like to do compression calculations for our own cylinder heads.
Thank you.
Old Dec 9, 2018 | 09:12 PM
2010Imperial's Avatar
WOw! Nothing!?!?
