Building An LS3
Old Feb 28, 2019 | 08:37 AM
MechMan1's Avatar
Default Building An LS3
I am currently saving up for an LS3 build I want to do to drop in a 4th Gen Monte SS. I would like to make close to 600 crank horse power. Trying not to be married to any one number. This is going to be a NA motor nonstroked. I plan on using a stock LS3 intake with a 92mm throttle body, Chevrolet Performance CNC-Ported LS3 Cylinder Heads part 88958758, still have to figure out the cam (will change the valve springs once cam is figured out), 99.9% going to convert to manual, 12 bolt 3:73 gears, and will up the compresson to at least 11:1. I know that I have a lot more to figure out to get a better idea of the power it will make but is this a good start? I have time to save at the moment so at least in theory money is not an issue. any advise is most apperciated.
Old Feb 28, 2019 | 09:38 AM
HioSSilver's Avatar
That will be gravy with the right intake. We just installed gpi heads and ss4 cam in a buddy's c6. We're hoping to see 550whp range.
Old Feb 28, 2019 | 10:16 AM
As Hio said, easy shot! A good LS3 with the right induction and cam will do 600+/- in its sleep!
Old Feb 28, 2019 | 10:17 AM
MechMan1's Avatar
What would you suggest? I am keeping the motor naturally asperated.
Old Feb 28, 2019 | 11:39 AM
HioSSilver's Avatar
I suggest you say how fast you want the car at the moment and go from there.
We should have some hp numbers after this weekend.
Old Feb 28, 2019 | 12:26 PM
KW Baraka's Avatar
Originally Posted by MechMan1
I am currently saving up for an LS3 build...….Chevrolet Performance CNC-Ported LS3 Cylinder Heads part 88958758...…..
I would go with Texas Speed ported LS3 heads, milled to achieve the CR you're looking for. Abot $750 if they port your stock heads.
https://www.texas-speed.com/p-1388-p...d-porting.aspx
I'd also have the LS3 ported and radius Rodded by Gwatney Performance.
https://gwatneyperformance.com/product/ls3-intake-mod/
Then I'd contact Cam Motion for their cam recommendation.
But hell....that's just me.
Best of luck!
KW
Old Feb 28, 2019 | 07:13 PM
big hammer's Avatar
600 crank is pretty easy for an ls3
Old Mar 1, 2019 | 03:42 PM
Darth_V8r's Avatar
Moderator
Just bolt on some rpm. Ls3 likes to rev
