Can I remove the metal insert on the bottom of a FAST 102?
Old Mar 24, 2019 | 06:31 PM
98RedBird's Avatar
Default Can I remove the metal insert on the bottom of a FAST 102?
Had heads shaved a bit, so the bolts are a little tight but fit on all holes except the 2 with the metal inserts in the middle of a FAST intake.
Can I remove these? what purpose do they serve? If I cannot remove them what options would I have in getting this to fit?
Thanks
Old Mar 24, 2019 | 09:07 PM
slogo's Avatar
Can you just open them up with a carbide bit? look real close wouldn't take much, or just drill out slightly.
Old Mar 26, 2019 | 12:00 AM
cmysix's Avatar
those are "stops" to try too keep you from over tightening, when heads are milled a lot they mill the manifold too, so it will fit.
