LS3 Throttle Response - Stock TB or 102?
Old Apr 10, 2019 | 07:53 PM
Bazman's Avatar
Default LS3 Throttle Response - Stock TB or 102?
Will the difference be noticed or minor?
Off boost part throttle?
Tip in vs Mash it
I currently run a 102 billet TB (DBW) with piping from the intercooler that runs from 2.5" outlets to 4" into the TB. I was wondering about going going down to a stock TB to pick up response. I doubt there would be any power loss as I'm not pushing hard and won't see north of 1000rw. If the difference is not great I'll stick with what I have.
Looking to build a forged blueprinted LS3 with stock stroke but run Darton MID sleeves and take it to 4.125" bores, add studs top and bottom and build a durable 388 that I can lean on lap after lap and day after day. I can't afford ITBs so thought I'd stick with the stock LS3 intake and wondering if TB is ok being so big
Old Apr 10, 2019 | 09:03 PM
Smokey B's Avatar
Thinik cam would be more influential Vs a tb size if air is being forced in..... Bigger tb can't nor won't hurt hp with efi. Get the baseline tune and idle right & what's the diff.
Old Apr 10, 2019 | 09:18 PM
Bazman's Avatar
Cheers Smokey, that's what I'm hoping. It's a nice TB so prefer to keep it
Old Apr 11, 2019 | 10:09 AM
big hammer's Avatar
TB size doesn’t matter unless it’s too small
Old Apr 11, 2019 | 02:43 PM
Kfxguy's Avatar
Ignition timing in non boost areas affects response, so does fueling. A larger throttle body should make it MORE responsive.
Old Apr 11, 2019 | 03:05 PM
Bazman's Avatar
Thanks guys, for a turbo it is actually quite responsive off boost. I run about 38 degrees timing off boost on light throttle and fairly lean, so response is about as good as a stock LS3. Was just seeing if I could pick up on that lol Anyone who has been around a race carb build or an ITB setup knows what uber response is. Pretty hard to get that in a turbo
