GTO Timing Cover Differences
Anyway, I bought a slew of parts and prepared for a major maintenance. Yesterday I began with removal of the radiator, water pump and some other stuff up front. What I found made my heart sink:
That timing cover looks like it has a window cut for a cam swap. I immediately started worrying this was a raw deal where the seller had major issues, slapped some junkyard parts together and sold the car as "stock". However, after I cleaned up and got to the internet after dinner, I searched '06 GTO timing cover. The first image result on eBay showed one IDENTICAL to what I have. I mean, same three raised bosses on the boundary of what appears to be the cut. They had pictures of the inside of the cover, no cuts.
Since I couldn't find any additional information, I'm asking here: is that really what a stock LS2 GTO timing cover looks like? Is there a chance this cover is stock and not modified? I should know in the next few days when I can pull the cover, but I wanted to see what y'all know about this, as I've never seen it before.
Not sure why they have the square window look, but it is not for a cam swap as the gear would not come out.
I'm learning more and more as I dig deeper into the motor. The valve covers are just like LS3 with the long fresh air PCV nipple and the baffles inside that run the whole length. And they were so clean on the inside, I just can't believe they're original to the 160K mileage the car represents (they may not be). More as I dig.
The cams are different too. LS2s use a single bolt sprocket while the 1s and 6s use a three bolt.
Before anyone is confused with your response, the GTO LS2 cam is a 3 bolt cam. Though a 1 bolt cam was available, it wasn't in the GTO and it was a different part number.
New flexplate holder is supposed to be delivered today, but I don't think I'm allowed to work on the car tonight... answer later this week.
The suggestion being that if you had to start over install an LS6 lifter cover and extend the harness to fit the new knock sensor position. If you converted the timing cover to a 1 or a 6, it would provide a wide variety of three bolt off the shelf cam grinds. Although it is improving today, there are fewer 1 bolt cam options. Also, even though your motor has a three bolt set up, the readily available three bolt 1 cams will not work with a front mounted sensor. There is no misinformation provided, rather a misunderstanding of my meaning.
Good luck.
And a cam picture to show the GTO LS2 cam is 3 bolt, in case there was still question...
So now that's resolved, I'll elaborate on my plan. In addition to the water pump leaking, the car had bad lifter tick when cold. With that and 160K miles, I decided to undertake a refresh of some seldom accessed parts that would be touchable when the water pump was off. This includes a replacement LS2 cam (stock), new valve seals and a VJ, trunnion upgrade, new oil pump, new seals where appropriate, powder coating stuff while it was off, just a general attack of long-term consumables. I never thought I'd see a worn timing chain damper, but sure enough, the old one had a couple grooves lightly etched in on each side. In the end, it'll be a reliable, stock-ish LS2 that will handily support some bolt-ons like an intake and full exhaust.
