90 Degree Brake Booster Fitting?
Old Sep 15, 2019 | 01:26 AM
InfamousRacing's Avatar
Default 90 Degree Brake Booster Fitting?
I've got an LY6 that I've just swapped into a Chevy Colorado. The intake is right up close to the firewall. I'm familiar with this fitting:
https://www.amazon.com/gp/product/B07DWHJR2Z/ref=ox_sc_act_title_1?smid=A1TNMI4LHV0ZX&psc=1 https://www.amazon.com/gp/product/B07DWHJR2Z/ref=ox_sc_act_title_1?smid=A1TNMI4LHV0ZX&psc=1
Does anyone make something like that in a 90 degree? Or what are some other solutions?
Intake is installed and truck is running, so I don't really wanna remove the intake to drill/tap the hole.
Thanks
Old Sep 22, 2019 | 04:28 AM
brandon6.0's Avatar
Contact ict billet im sure they do custom stuff.
Or take tht plug u pictured and have some welding shop weld a aluminum 90* barb to it. This would be simplest way.
Old Sep 22, 2019 | 04:31 AM
brandon6.0's Avatar
Another option is some trucks came hydroboost setup. These trucks used a plug at the rear of intake, with no brake booster vaccum line. Maybe u could plug it off and pull vaccum off another source.
Old Sep 22, 2019 | 01:55 PM
Yes, this intake actually had the block off plug from the factory but the it's in a different application now.
Welding a 90 to the aluminum fitting is a good idea.
Otherwise I may pull vacuum from the factory PCV spot in the middle of the intake.
