New Engine for New Owner
Re: The LSX Swap Build Thread
LME 440 LSX Longblock Package - STREET KILLER -
700+HP Monster - Pump Gas Compatible 12.0:1
Compressio Ratio - HYDRAULIC ROLLER
Balance & Bluepri... Balance, Blueprint & Assemble Shortblock: fully deburr
block, line hone block w/ ARP main studs, deck block to
desired deck height w/ BHJ deck true fixture, bore block
on 4 axis CNC, Diamond hone block w/ torque plates,
balance crankshaft to 1/4 oz. in. tolerance, hang pistons
on rods, check all bearing clearances, file fit rings,
assemble shortblock. **All Tolerances & clearances
Optomized For Customers Specific Application
GM LSX std. deck. GM Bow Tie LSX race block. Features: priority main
oiling, billet main caps, increased cylinder wall & deck
thickness, 6 bolts per cylinder(for added improved head
gasket sealing. Block comes w/cam plate, rear cover, all
plugs & dowel pins
Compstar 4.125 St... Callies Compstar 4340 forged 4.125" stroke crankshaft w/
2.100" rod journals
Compstar LS L/J. Callies Compstar 4340 6.125" H beam connecting rods
w/ 2.1.." journal and ARP 2000 7/16" bolts
Diamond LS Shelf Diamond forged pistons w/ tool steel wrist pins & anti
friction coating on skirts: Includes stainless chrome top
ring (for high heat applications, napier 2nd (improved oil
control), 3mm oil rings(reduced friction & improved oil
control)
Clevite MS 2199 H mains, Clevite CB 663 H rods, Dura
Bond CH-23 cam bearings
LSX main studs ARP Pro Series 12pt. main stud kit
Assemble Longblo... Assemble Complete Longblock & DYNO TEST
ENGINE: degree cam, check piston to valve clearance,
adjust valve train geometry & lifter pre load, install oil
pump & heads, Modify & Install Covers
Brodix BR7 CNC Brodix LS7 LME CNC Heads: Competition Valve Job,
Flow Testing, Chambers Milled To Desired CC, Titanium
2.200" Intake Valves, Stainless Exhaust valves, LME
Dual Valve Springs (good to .660" lift), Titanium
retainers, machined locators & locks, Viton Valve Seals,
Bronze Guides (chamber volumes measures & adjusted
for compression, CNC work hand blended into valve job,
spring pressures measured & adjusted for camshaft)
LSX 6 bolt studs ARP 2000 Pro Series 12 pt. head studs for LSX 6 bolt
block (offers 40% more clamping force than the standard
ARP 8740 chromoly material)
Cometic MLX R 4... Cometic MLX 6 Bolt Head Gaskets with 1/2" Bolt Holes
For Extreem Boost Applications 4.200" x .51" x 6 bolt x
1/2"
Cam Motion LSx ... Cam Motion 8620 Billet Core Custom LSx Hyd. Roller
Camshaft
LS7. GM LS7 hydraulic roller lifters
Manley 3/8" x .135" Manley One Piece 3/8" x .135" Heavy Wall Pushrods
GM LS7 intake rocker arms
LS7 exh. GM LS7 exh. rocker arms
Comp Cams Comp Cams LS Intake & Exhaust rocker modification
(installed)
Roll Master Dbl. 4... Roll Master Double Roller Timing Set w/Torrington
Bearing & Nitrided Gears
Melling 10295 HP. Melling 10295 high pressure, coated oil pump/ ported
LS2 cover. GM LS2 front cover w/ cam sensor, gasket, seal, and
bolts
GM LS2 GM LS2 valley cover w/ gasket and bolts
LME Billet LS w/... LME Billet Aluminum Valve Covers: Includes two -10
AN Fittings, Two -10 AN Plugs, Factory Gaskets,
Stainless Mounting Hardware.
Powder Coating Powder Coating
GM F body. GM F body aluminu oil pan w/ gasket & bolts
GM F body. GM F Body pick up tube
GM F body. GM F Body windage tray
ATI F-body ATI SFI F-body balancer w/ A/C pulley
ARP LS1. ARP LS1 balancer bolt
MSD LS7 MSD Air Force LS7 Intake Manifold (makes 24HP over
FAST)
NW 102mm Cable Nick Williams Billet 102mm Cable Throttlebody
FAST 65# LS3/LS7 FAST 65# Fuel Injector LS3/LS7
GM Non resistor ... GM Non Resistor Spark Plug Wires
NGK TR6 NGK V Power TR6 spark plugs
GM LS coils GM LS coil pack
