Throttle body cable adjustment
Old Sep 26, 2019 | 10:29 AM
Dcpilato's Avatar
Default Throttle body cable adjustment
Hey guys. Need some help. Just picked up a 2002 WS6, the previous owner did the traction control delete. I reinstalled it. My throttle body isn’t opening all the way when the gas pedal is fully depressed. How do I adjust this. Also the cable that was reinstalled on the traction controls module next to the battery, seems loose also. It’s the one right on top. Thanks in advance for your help!
Old Sep 26, 2019 | 10:39 AM
Is there any slack in the cable at idle? If so, tweak the brackets a bit to take it out, and full throttle should return.
Old Sep 26, 2019 | 07:06 PM
brandon6.0's Avatar
If its an aftermarket tb with 2 cable slots. Move cable the the furthest slot. The closest slot is used for tb spacers or nitrous plates.
