LS2 with FBody Crank Pulley Accessory Drive Question
1. Am I correct in thinking that the accessory drive brackets, cam pulley, alternator bracket, power steering, need to come from an fbody vehicle? From what I've read the pulley in a corvette crank pulley sits closer to the engine than the fbody camaro.
2. Will I need to buy a fbody water pump to line up with the fbody crank pulley, or will an LS2 water pump work just fine?
Thanks.
Frank
