Bent intake #4 - 6.0L 2008 Yukon
I have a 2008 Yukon Hybrid, 140,000 miles. The hybrid has the 6.0 engine. I hope this is the right forum. As a back story on the engine, I've had it for 18 months, and it appears the previous owner didn't change the oil often enough, as I've had several rounds of a plugged VLOM screen. I've been doing shorter than normal oil change intervals and it appears that it is pulling the sludge and cleaning up the engine. I don't know if that relates at all.
I got a serious mis-fire on #4, and when checking compression, I got ZERO compression on #4. I did a pressure check and got leaking out the intake. I pulled the head, and #4 clearly wasn't seating, so I took it to to a machine shop. They said the valve was bent. I cleaned the top of the piston and couldn't find ANY evidence of a valve strike. I would think if it was enough to bend a valve, I would have some evidence on the piston top. Given the history of bad oil, I did replace the VLOM, but didn't change the lifters. I debated about the lifter, but I could see no sign that anything was wrong. The lifter trays were still pliable and showing no signs of brittleness or cracking, so I used those again. The valve wasn't burned at all, so it went from sealing to leaking as a sudden event. The shop checked the head and said it was flat, and checked the springs and they measured OK. I put everything back together, using AC Delco studs and a gasket and followed the torque / degree sequence. They did say they've never seen this before.
Everything was fine for 3 days, then bang, the miss is back. What the heck caused the bent valve to begin with, and is there something I should have checked or replaced? I need to repeat the leak-down test tonight and figure out if it's the same intake valve, I blew a head gasket or something else. But before I go doing anything, I thought it was worthwhile to check here.
I do think at least the first one was PTV. Second one - if it is another bent valve. I would consider replacing both cam and phaser in case there is a grind error on the cam at cylinder 4.
Does the engine have one or not? I'm not sure. I expected an L76 engine, but it has cathedral ports and I thought the L76 has square ports. It is aluminum block and aluminum head.
