Coil test
Old Aug 8, 2020 | 04:31 PM
showdog75's Avatar
Default Coil test
Is there any way within reason to test coil packs? I'm chasing a intermittent miss when my rpm's come up around 4g. Tuner suspects possible broke valve spring but I'm going to cover the easy stuff first.
Old Aug 8, 2020 | 08:34 PM
rkupon1's Avatar
Im literally chasing the same scenario with my nova. But at 6400 rpms. Gunna try a new set of coil packs as these are 2nd hand and TMU. I m hopn its that easy but i m doubtful. I was told to change dwell settings and see if problem moves up or down rpm range. Im also pulling VCs and checking lash. After these two, i m thinkn its electrical. Also need to add some baffles to my VCs. Rockers are slingin oil right into both my -10 lines and filling the catch can
