Carquest auto replacement water pump, wierd stuff.
Old Feb 28, 2021 | 08:35 PM
S_Sprouse's Avatar
Default Carquest auto replacement water pump, wierd stuff.
Car is a 2000 ws6 trans am a4. I was under the impression there were no more ls1 water pumps being made and they moved over to the ls2 water pump. I replaced mine today in a couple hours with a carquest water pump and a two piece housing stat, to find out, the LS2 style thermostat wouldn't fit in the "new" water pump i bought. As far as i am aware the one i replaced today (leaky one) was original ( with the tabs/ear at the housing of the thermostat housing). So i removed the two piece syle ls2 stat and replaced it with my old thermostat into the new water pump and it worked. So the New housing/tstat made my car kick its fans on below 210 on the gauge ( high fans) and wouldn't turn off! The old ls1 style tstat/housing worked correctly in my "unknown ls2/ls1" style pump. WTF is going on? Now i am afraid bc idk what thermostat i will need i the future when the original stat stops working eventually. Any tips or advice?
Old Mar 2, 2021 | 05:48 AM
Stampede4ever's Avatar
So, did you ask to see if they had an LS1 thermostat? If not, check rockauto.
Thanks.
