L92: Cam sensor / Cover / VVT delete
The cover has a machined surface and 2 bolts for the cam sensor
The Cam sensor is a single bolt and is an ACDelco 213-3826
https://photos.app.goo.gl/HNFCBZwSpyPj2ohP6
I was poking around Rock Auto looking at pic's and it appears some covers have 2 bolts while others have 1.
I'm running a Holley Terminator X Max (DBW/4L80E), skimmed thru the instructions and no mention of specific cam sensor.
Do I just run the timing cover/sensor combo I have or do I need to do something different? Also what bolts should I use, thinking I shouldn't go too long!
Just wondering if I can use what is there and plug the other hole. If not I can buy the GM version.
Also do I need the cam sensor connector with the Holley Terminator kit? Thinking yes but the install directions didn't make it clear, probably time to watch a few vid's.
