Smaller steering pump pulley ok?
Old Jun 4, 2021 | 11:32 PM
78TA_In87's Avatar
Default Smaller steering pump pulley ok?
I am using a 5.5 in diameter steering pump pulley. I have an extra pulley that's never been used and it's 5.24 inches. Will that be OK to use on my LS3 engine? My pump may be bad so I might want to replace it with a slightly different one that allows for a cleaner and shorter hose route (and the pulley in the car now does not have the correct bore diameter like my extra pulley does). And if I can use it, will it require a shorter drive belt or can the tensioner be adjusted to handle it?
Old Jun 5, 2021 | 12:03 AM
You're only talking about .26 decrease in diameter, or .13 radius difference. The tensioner SHOULD take up that slack, depending on where within its travel it is now.
Old Jun 9, 2021 | 11:23 PM
wannafbody's Avatar
Does the size of the pulley affect the steering feel?
Old Jun 9, 2021 | 11:55 PM
To a degree, only if it is too large, not allowing the pump to keep up with rapid steering inputs.
Old Jun 10, 2021 | 07:02 AM
Haggar's Avatar
Smaller pulley = higher rpms on the pump. In theory, if you overspeed a power steering pump, it can cause aeration in the fluid which isn't good. This I think ends up being more an issue if you are using it for sustained high rpm like road course.
