Belt Alignment Issue
551668-3
LS Truck-Billet Low Mount Alt Bracket kit w/ pulley
Serpentine Belt - 805K6
Tensioner: Katech A4425
Power Steering: Turn One w/ 2012 GM Bracket
W/P - 2014 Camaro SS Stock
Damper - ATI 918628 (2010-15 Camaro SS LS3) (no a/c)
I've used the laser alignment tool and it hasn't really helped much. This is such a stupid problem to have. Does anyone see any issues with the FEAD components I'm using?
The belt frays at the front and you can see it running off the harmonic damper.
I ended up switching to ICT Billet brackets and my belt issues went away. I was constantly breaking belts or throwing belts. Spent probably $200 on belts lol
I did laser align all my pulleys and they align. I couldn't get the best shot to the damper, but it looks okay to me.
I'm planning on removing the Katech Tensioner and installing an OEM spring actuated. I hope I won't have any clearance issues so I can test tonight.
Here is a test I did last night with my 4-rib belt to check movement.
I have swapped to an OEM tensioner and re-installed the alt. bracket after shaving the idler spacer by 2 mm to move the pulley closer to the block.. I want to test if that has any improvement.
Picture below was from a few weeks ago.
I agree with the shoulders being low on the damper. I went hot rodding last night and it didn't jump. The belt looked in line from the p/s - idler - damper, which is a first.
Once I believe this is working, I will purchase a higher quality belt than these Duralast -- most likely Gates.
