Do I really need an exhaust cross-over pipe
In some cars, it's worth AHELLUVALOT MORE THAN any 5 - 10 HP. In some, it's less than that.
Only way to know for absolutely sure is to put one in and see.
Best place to locate it, is where the exh temp is the highest. An exh system is a resonant tube, therefore has a pattern of high and low pressure regions all along it. Since temp varies directly according to pressure, the pipe will be hottest where the pressure is highest. You can use a stripe of temp-indicating paint to find the hot places. The greater the difference between the hottest and the coolest places along the pipes, the more likely you will benefit from an H-pipe (crossover) or X-pipe. If you find the variation along the pipe to be large, you will probably pick up power from installing one. Put the crossover at the hottest place along the pipes that you can, as close to the motor as you can, given the constraints of the chassis and whatever else.
I'd bet it'll run better with one, than without.
Just exactly how much is anybody's guess. Looking for excuses up front for LOSING ("it's good enough") isn't the best way to go about WINNING.Think of it this way: you're spending $xxxx, and getting yyyy results. A crossover (H-pipe especially) is something your local muffler shop can do if you tell em where you want it, in a few minutes, for less than $100. Maybe less than $50 if it's at the same time as putting on this hypothetical dual exhaust. So, if you could spend $xxxx+50, and get yyyy+100, but decide not to, are you making the right decision?
Sounds like a very cool car and sweet project. Would love to see a picture.
Having had a 72 C3 in the family for like 40 years, our collected wisdom, earned the hard way is: Do it right & Do it once.
Is the car a keeper? Do what suits you. Pleasing yourself is what matters.
Is the car a flip or short timer? Do the cross over. Lot of folks like myself see it as a half measure and half assed project to not do it. I'd wonder what other corners were cut with the car if it was offered for sale with the LS3 swap and no X pipe. That probably sound harsh but it's honest. No offense intended.
FWIW - My experience is both Small Block Chevy & LS engines sound better with the X pipe. Both my 72 with a Dart 400 & T/A w/416 and the X pipe improved the sound quality.
