Gas pedal replacement Question
Old Nov 2, 2021 | 01:50 PM
69Shark's Avatar
Default Gas pedal replacement Question
Hey all my LS swap friends,
I stuffed an LS7 into my 69 Corvette a while back with some help from you so I am back with another question.
For my swap I used an original "Fly by wire" C6 Z06 Corvette gas pedal. Wonderful it is I might add . . . . .
The pedal is too long and mounted at an angle such that it hangs under the brake pedal a bit. So much that I literally drive like Sammy Hagar! ( One foot on the brake and one on the gas! )
I am OK with that. however it is not really safe for 1 foot driving. If you hit the brake in a panic you are likely to hit the gas also!!!!! YIKES!
Has anyone swapped just the pedal and not the entire assembly with a different or shorter/shaped pedal?
There are times when having someone else move or drive my car would be helpful but I just don't trust that an accident will not happen.
Can I pop the pedal off the assembly and put a more suited one on?
Again,
Thanks for any input!
Scott
69 Corvette Convertible
LS7 4L75E
Old Nov 2, 2021 | 01:52 PM
Any way to just bend the arm the pedal is mounted on?
Old Nov 2, 2021 | 02:15 PM
69Shark's Avatar
Excellent question, I do not know and have not looked.
. . . . and that is why I am asking! Ideas my feeble mind do not come up with! LOL!
Scott
Old Nov 2, 2021 | 06:07 PM
The C6Z pedal has a metal arm and would be simple to shorten (cut and weld) and/or mold to your liking. I’ve got a ‘70 Chevelle that has been LS swapped, I did pedal mods like this to get it exactly where I wanted the pedal to be. Unhook the connector, unbolt the pedal and remove it to do any modding.
Old Nov 3, 2021 | 11:53 PM
69Shark's Avatar
Good to know, Thank you very much!!
Scott
