Throttle body performance
Old Feb 18, 2022 | 02:28 PM
Michael Gerace's Avatar
Default Throttle body performance
Is there any performance difference in going with a new dbw GM 90mm throttle body as opposed to a new aftermarket 90 or 92 throttle body? I guess what I'm getting at is if I'm set on 90 or 92mm do I get the factory one or the name brand aftermarket one size being equal and why?
Old Feb 18, 2022 | 02:30 PM
This is on a 6.0 truck build with cam and Trickflow GenX heads and tbss intake manifold
Old Feb 18, 2022 | 02:50 PM
theunderlord's Avatar
In the situation you've described I would go with the cheaper option that integrates best with your tuning software / factory ECU.
Old Feb 19, 2022 | 02:03 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The best case scenario is no difference. The likely scenario is that an aftermarket DBW would require recalibration in your tune. Even in the "unlikely" case that the factory is more expensive, I would stay with what your tune is already calibrated for. Also, some cheaper aftermarket TBs have been known to have multiple issues.
