Decoupling alternator delete
Old Feb 20, 2022 | 08:49 AM
ballas03's Avatar
Default Decoupling alternator delete
Hey I have a ls3 in a s10 I use for drag racing and am using corvette accessories out of a c6 and I keep breaking the decoupling pulley on the alternator. I was wondering if anyone knows where to get a non decoupling pulley or what alternator I can use with my current accessory set up thanks
Old Feb 20, 2022 | 10:02 AM
Z28SteveA4's Avatar
I believe that’s a two wire alternator correct?
Old Feb 21, 2022 | 07:23 AM
ballas03's Avatar
It is a 4 pin connector with on blank pin. I am only using 2 pins though
Old Apr 6, 2022 | 07:47 PM
FormulaBoat's Avatar
The pulley likely has a black plastic cover on the nose. Drive an ice pick through the center, then pry it out. Then weld the center hub to the outer pulley.
