S197 5.3 swap
Old Feb 26, 2022 | 12:45 PM
jacobkerner's Avatar
Default S197 5.3 swap
I have a gen 4 5.3, I am swapping into my 06 mustang GT. It’s an auto and has the 5r55s. My goal is to swap and have it running asap, then i can build it from there. Does anyone know if i can run it on this trans? Maybe with an adapter plate? I can’t find much information on it. Again, i would upgrade trans probably this fall, just want to get it running. If not, does it fit to the stock 05-09 mustang manuals transmissions? Maybe if it doesn’t bolt to 5r55s, i can pull a manual from a junkyard and swap it for cheap until i upgrade
Old Feb 26, 2022 | 12:46 PM
If i didn’t post in the right place, my bad, pretty new
Old Feb 26, 2022 | 01:21 PM
theunderlord's Avatar
Welcome man, be sure and check out the LS/LT conversion forum, might have better luck in there!
https://ls1tech.com/forums/conversions-hybrids-28/
