LSX 454R engine
Old Apr 29, 2022 | 05:50 AM
Sting1's Avatar
Default LSX 454R engine
Does anyone know what ATI balancer that was used on these motors? Looks like Corvette but im getting about 4 1/2" from the block to the front of the balancer. I'm hoping to just buy a alt bracket instead of making something.
Old Apr 29, 2022 | 06:42 AM
Double06's Avatar
What car is this going in? I think it also depends on the oil system does it have the LS7 dry sump pump or a wet sump oil pump. The dry sump you will probably be using the C6 Z06 balancer. If you do that one make sure you go with the normal size drive balancer as the AC pulley has a raised shoulder so not to throw the belt.
Old Apr 29, 2022 | 11:25 AM
Sting1's Avatar
Default 454r
It already has a ATI balancer on it from GM. I'm pretty sure it Corvette spacing after finding more info. It's a wet sump setup. Thanks for the info.
