Water pump removal and remote pump
Old May 2, 2022 | 03:41 PM
NYLS's Avatar
Default Water pump removal and remote pump
I'm going to be removing the stock LS3 water pump and going with a remote PWM pump setup, AN fitting retrofit. Anybody have a good suggestion as to the recommended flow and fitting setup? I've seen kits with 4 in/out AN fittings, 2/side, some kits with bridge hoses, and some kits with solid bridges. I'll likely be making my own hoses, unless someone here has recommendations for a solid kit. It's going in a custom car, so eye-candy is nice, but not if it comes at the expense of solid mechanical durability.
