MAP Sensor for TBSS?
I just looked up for a 2006 Trailblazer. A dozen different ones for widely varying prices.
But get the AC Delco (2134434, $55.79) one for best results
How do you tell if it's a 1-bar, 2-bar, or 3-bar? Let's say I want to run 20lbs of boost. How many bars is that?
I’m not trying to insult your intelligence here, but from your post there’s not much actual information. Unless you run negative spark values on a build as stated so far, it will inevitably fail. Best case for a build going for that much boost is reducing your SCR to around 8-9:1. Lower the better honestly. I’d lean towards 8:1 for 20#.
You do you though. Take that stock block to 20 and report back.
The only calculator I could find for dynamic compression, uses the valve events at .006" lift. All the cam specs are listed at .050" lift. This engine has the BTR stage-2 truck cam (212/218-113). I'm not sure what the dynamic compression comes out to with this camshaft.
