LS7 crank in Lq4
Old Jul 23, 2022 | 09:44 AM
MAjdi ALharthi's Avatar
Default LS7 crank in Lq4
I have Lq4 with :
LS7 crank
LS7 rods
X58
ls3 oil pump
ls3 timing cover
ls3 heads (upgraded)
comp cam
knock sensor hooked to the side of the block
cam sensor in the front cover
Oil pan
almost everything swapped.
my question,LS7 crank is longer and I’m going to use the spacer for it, but what balance I need to use to to line up the belt to the water pump pulley alternator etc.
The engine will be in a 2013 Chevy Caprice
thanks a lot
Old Jul 23, 2022 | 03:54 PM
Which accessory setup are you using? I will guess Corvette as that is the only LS7 application. All other accessories need to follow suit. As in, Corvette spacing.
