2010 chevy 3500 standalone swap
Old Oct 2, 2022 | 08:56 PM
Clyde51vt's Avatar
Default 2010 chevy 3500 standalone swap
Hey guys. So I got my ecm tuned from a tuner a d I've still got 27 codes. Lots of them are duplicates. I've still got evap codes. Still got rear o2 codes and I've got a few for bank 1 knock sensor low and I've got a crank shaft relearn code and coolant temp codes. Not entirely sure how to go about fixing these "low" codes. I remade all the power and grounds. Cleaned all grounding surfaces. I don't have the serpentine belt on right now because I don't have radiator or power steering hoses hooked up. Any ideas what I should do next?
Old Oct 6, 2022 | 09:23 AM
gagliano7's Avatar
Alot of those codes need to be programmed out since you won't be using them on a standalone setup. You need a tuner that is familiar with LS swaps. You should put this in the tuning section.
