LS2 Timing Cover Crankshaft Seal
Old Dec 25, 2022 | 04:47 PM
Lght Spd's Avatar
Default LS2 Timing Cover Crankshaft Seal
I just pulled the crankshaft seal out of the front timing cover on my LS2 while doing a harmonic balancer swap. I’m not having any luck installing the new seal on the timing cover while it’s bolted to the motor. I’m being told to pull the cover and install off the engine. As I dive deeper into that process it seems way to labor intensive. Need to drop the oil pan? I’d prefer to find a tool that is the same OD as the seal and drive it into the timing cover using a dead blow hammer?
is this possible? If so who makes the tool for this procedure?
Old Dec 26, 2022 | 08:37 AM
Rich-L79's Avatar
Do you have a set of large deep sockets? Or you could take a piece of wood like a short piece of 2x4 and drill a hole to let it clear the crank snout.
Old Dec 26, 2022 | 10:45 AM
RB04Av's Avatar
PVC pipe
Old Dec 27, 2022 | 01:13 PM
Lght Spd's Avatar
Originally Posted by RB04Av
PVC pipe
Thanks My Man. A trip to Home Depot for a 2ft section of 2" diameter PVC cut down did the trick!
