Washer, Harmonic Balancer
Old May 27, 2023 | 07:07 AM
PlymouthBarracuda's Avatar
Question Washer, Harmonic Balancer
Could anybody help to find the correct part number of the crank pulley Washer ? After removal crankshaft balancer it's washer became unserviceable.
I searched everywhere and can't find the PN to order.
I ordered new GM crank pulley but it came without the washer.
Now I have oil leak from the front crankshaft seal....
2011 chevy camaro L99 6.2 auto transmission
I ordered PN 12578073 that is very similar but it's too small physically. I attach image
Old May 27, 2023 | 10:15 AM
QwkTrip's Avatar
Bolt is not reusable, so you need a new bolt too. Just get a bolt and washer kit from summit racing or anywhere.
Old May 27, 2023 | 12:33 PM
Question
Finally I found it, genuine PN from GM is 12603843 (old version is 12600525)
Old May 27, 2023 | 01:06 PM
Could anybody help to find seller of the pn 12603843 or 12600525 ?))
Old May 27, 2023 | 02:15 PM
To reiterate the post above, buy BOTH the bolt and washer as a set from Summit or almost anywhere else.
The bolt is NOT reusable.
Old May 31, 2023 | 09:29 AM
LS1Formulation's Avatar
It's literally $30 for a reusable ARP bolt and washer. Just buy it and be done with it.
Old May 31, 2023 | 09:15 PM
yes, thank you, but GM don't produce anymore 12603843 or 12600525 and Summit Racing have zero in stock.
new washer part number is 12674588 and I have new GM bolt .
Last time I installed this pulley by tightening a bolt, however I have seen it installed by heating
Old Jun 1, 2023 | 08:25 AM
LaBLKv6Z's Avatar
Highly recommend using OEMTOOLS 27306 long reach harmonic balancer/pulley installer. This is a loaner tool that can be sourced at Autozone.
