Head and Cam choice for 416 LS3
Old Jun 10, 2023 | 12:31 PM
DripGawd's Avatar
Question Head and Cam choice for 416 LS3
I am trying to figure out the best head and cam choice for the items I have purchased thus far. I will list the items and I want suggestions on the best combos for my setup. I'm not trying to break the bank but I also want a reliable and sound setup. Quality first and foremost. I am trying to achieve about 525 rwhp. Many thanks for any suggestions.
Engine block: Gen IV LS3 4.070 bore
Rotating assembly is as follows:
- TSP 4.00" Stroke Forged Crankshaft, 4340 Steel, 6-Bolt Rear Flange, Wet Sump, With Reluctor Wheel
- Lunati Forged LSx 6.125-Inch H-Beam Connecting Rods with ARP 2000 Bolts, .927-Inch Pin
- CP Pistons Forged Piston Set: 4.070" Bore, 4.00" Stroke, 1.110" CH, -3cc Flat-Top, Includes Wrist Pins & Steel Nitrided Top/Napier 2nd Ring Set
- ACL Main Bearing Set for Standard Clearance, Chamfered
- ACL Connecting Rod Bearing Set for Standard Clearance, Chamfered
Transmission: PerformaBuilt 4l70e stage 2 (up to 700 whp)
Rear End: Currie 9 inch with 3.55 gears
