AN hose end install while on vehicle?
Old Aug 1, 2023 | 08:34 AM
grinder11's Avatar
Default AN hose end install while on vehicle?
I may be posting this in the wrong place, so Mods, please relocate if need be. Here is my question, and problem:
Has anyone tried to install AN #10 hose ends while hoses are on the vehicle? My vehicle is a 2000 C5 Vette, with an LPE oil cooler adapter on the side of the block. Its inaccessible without removing the old style Kooks headers. The old style Kooks are a PITA to R&R, so trying to avoid it. Thanks guys.
Old Aug 1, 2023 | 10:39 AM
RB04Av's Avatar
Sure. Can be done. Difficulty will depend on what kind of hose it is (PTFE can be MUCH easier), how much space you have to work in and how accessible it is, whether you have to cut the end off and it gets too short, etc.
Seems though, if you can get in there to the extent of even asking this question, that even if the cooler adapter is inaccessible, if you can get to the hose ends to disconnect them, you could pull the lines out and leave the adapter there.
Old Aug 1, 2023 | 03:07 PM
gjohnsonws6's Avatar
The hoses are already hooked up to the adapter and you want to change hose ends on the other side of the hose? I’ve don’t that many times, it’s no different than bench assembling. The only issue is cleaning out the debris but a q tip will handle that.
Old Aug 1, 2023 | 03:08 PM
In my experience Fragola 6000 PTFE is way more difficult to assemble than regular ends.
Old Aug 1, 2023 | 04:49 PM
grinder11's Avatar
I got a surprise "gift!" About 10 years ago, I changed oil coolers (I gotta stop this, lol!!!), and added a 2ft extension to the existing Aeroquip AN hose. I had forgotten about it until I tore into it this morning. I got lucky that the line that needed a 9" shortening was the one with the extension. So I simply removed the extension, took it to the bench, and shortened it by 9". Worked great. Thanks to all who responded......
Old Aug 21, 2023 | 09:53 PM
wester11's Avatar
someone just mentioned it, if they at tpfe it’ll be a challenge. I just changed my hoses around while installed. Needed to move my regulator and put a few an fittings on shorter hose. I don’t k ow if your done already but took 5 minutes and hasn’t leaked. Drain everything off the lines move some air in the garage
Old Nov 1, 2023 | 11:55 AM
Pb82 Ronin's Avatar
Bumping for using Pushlock style hose. Big fan of that Aeroquip/Eaton/Parker, etc...never run into assembly issues when running them, even when installed in a car. Hoo-ray first post too...I had thought I signed up for this forum a long time ago. Guess I hadn't.
