427 ls in a 2002 ta
Old Sep 13, 2023 | 06:03 PM
BA383TA's Avatar
Default 427 ls in a 2002 ta
I can't be the first to do this. What oil pan are you using to clear the 4 inch stroke and fit the K member. I have a umi K member. I called Summit and they couldn't figure it out.
Old Sep 13, 2023 | 06:25 PM
blackbyrd's Avatar
Ls7? Or custom 427
My 414 still uses stock stuff
Old Sep 13, 2023 | 07:49 PM
I would think that the Holley line of oil pans would work with your application. They are a slimline pan out front and a shallow..ish sump for ground clearance. But then again, I’m pretty sure I’ve seen guys run the OEM F-body pan with 4” stroke builds…
Old Sep 13, 2023 | 08:20 PM
LS1 TJ's Avatar
A number of years ago I had a LS2 block sleeved and stroked to 427 cubes. 4" stroke. I used a 2002 oil pan. No issues. I didn't assemble it but I think they had to space the windage tray away from the crank a bit.
Old Sep 13, 2023 | 09:56 PM
BA383TA's Avatar
It's a custom 427. Thanks. I'm looking for a new pan so I can sell my 5.7 complete to help fund the new engine.
Old Sep 14, 2023 | 08:58 AM
MuhThugga's Avatar
You can just get the Holley F-Body pan, or even the Dorman F-Body pan should work.
