Water pump for ls2 swap
Old Sep 24, 2023 | 01:42 PM
2fast4u07's Avatar
Default Water pump for ls2 swap
I知 dropping a 408 ls2 into my c5 but I知 not sure whether to use a ls1 water pump or a ls2 pump. I致e been given conflicting recommendations so I知 hoping someone knowledgeable can point me in the right direction.
Old Sep 24, 2023 | 02:45 PM
The front of aluminum LS blocks are all the same. Since the C5 came with LS1/6 engines, it would seem that an LS2 that resembles an LS1/6 in front would fit the best. That way all hoses will hook up right. My vote goes to LS1/6 water pump.
Old Sep 24, 2023 | 03:23 PM
LS1 TJ's Avatar
I would use whatever is called out for C5 Corvette water pump wise.
Old Sep 26, 2023 | 06:44 AM
02EBC5Z06's Avatar
This is the one you want.
https://www.summitracing.com/parts/a...ette/year/2002
Always buy Mexico made Delco pumps. The chinese (less expensive delco pumps) are hot garbage.
Old Oct 21, 2023 | 04:21 PM
Jimbo1367's Avatar
Cheaper on rockauto
