What MAP sensor should I get for the new engine?
Old Apr 5, 2024 | 08:32 PM
FCar2000TA's Avatar
Veteran: Air Force
Default What MAP sensor should I get for the new engine?
LS7 based 434, should be 725-750 BHP on moonshine. It will be 12:1 compression NA for the foreseeable future. Maybe something more one day
411 PCM will take a 2 bar, if I am not mistaken. Is there any down side to running a 2 bar instead of a 1 bar?
Old Apr 5, 2024 | 09:02 PM
TrendSetter's Avatar
If you aren’t running boost then you should use a one bar.
