L92 flexplate interchangeable with other ls?
Old Apr 13, 2024 | 10:42 PM
Edg214's Avatar
Default L92 flexplate interchangeable with other ls?
I got a l92 for 400 bucks and well it doesnt have the starter or flexplate. I want to source a second hand flexplate and starter to at least crank the engine over to check compression. Can i use a flexplate/starter from a 5.3? If one of you gentlemen have an extra of both you wouldnt mind to get rid of for cheap id greatly appreciate it!
Old Apr 14, 2024 | 04:07 PM
LS1 TJ's Avatar
The 5.3 flex plate and starter should be fine. In regards to the starter get one with the upgraded mounting block. I believe they take the same length bolts compared to the early LS starters that used one long and one short bolt.
Old Apr 20, 2024 | 05:28 PM
Edg214's Avatar
i did see that there was two models of starters. I was going to opt for the design that used two of the same length bolts. Thank you for the confirmation
By Brett Foote | 2026-06-04 05:00:17
