MAP Sensor Options for Manual Throttle
Old May 26, 2024 | 02:08 PM
Picone's Avatar
Default MAP Sensor Options for Manual Throttle
I’ve got an L92 with a Car manifold and Fast manual throttle body. The MAP sensor will not fit with the throttle linkage. Is there a simple product that rotates the sensor 90 degree to work? Do most people do a relocation, and if so, is there anything special you need to do so it reads correctly when it’s located somewhere else?
Old May 28, 2024 | 10:53 AM
Picone's Avatar
Well, I found a threaded adapter and I have a DMS relocation bracket. I can locate the MAP sensor a few inches away with a couple barbed fittings and some hose. Anyone see any issue with having 6" of hose on the MAP sensor.
I am just starting to install the Holley Terminator X ecm and harness. I see they have a built-in MAP sensor for some reason that eliminates this all together...which would add about 5 feet of remote hose, so I can't imagine 6" would hurt.
Motion Raceworks Threaded MAP Plug
DMS MAP Relocation
